91 Silverado 1500 problem
Old Sep 20, 2018 | 06:06 PM
Chevy91's Avatar
Default 91 Silverado 1500 problem
hello this is my first post. I have a 1991 Chevy Silverado. I recently changed the bulbs on the cluster and now it lights up no issue. But the new problem I have is that the gas gauge does read how much gas it has. I know this because I pumped $70 dollars and it reads less than a quarter. Any ideas how to help?? Thank you.
Old Sep 22, 2018 | 07:44 AM
SlimJim's Avatar
If this problem showed up after you pulled the cluster to change the bulbs, you probably pulled a wire off your fuel gauge. It's easy to break or short a wire when you are doing something like that. I would pull the cluster again and carefully visually check the wiring and you will probably see the problem. Let us know what you find. Good luck.
Chevy91
May 7, 2020 04:10 PM
altyson60
Aug 22, 2012 01:08 PM
CMG1002
Mar 12, 2010 12:41 PM
Miazda
Sep 30, 2009 10:33 PM
bigbadwhopper
Feb 26, 2007 01:53 AM
