92 Silverado light brake pedal
Old Feb 21, 2009 | 08:08 PM
jtdt175's Avatar
Default 92 Silverado light brake pedal
Ok, In December I bought a 92 Silverado to replace my V8 S10. When I got it I felt it had a light brake pedal. What I mean is that when you first press it the pedal goes down a bit, like halfway, before you get any pedal. Once it gets firm it stops the truck just fine. The brakes are good, just replaced the drum brakes today, I also checked out the front brakes and they looked great I would say about 70% left. There are no leaks in the system and the brake fluid does not change. When I purchased the truck the seller told me that the power brake booster was replaced by the previous owner I do not believe the master cylinder was. What I would like to know is any explanations of why the pedal would be so light. My uncle has a 1990 Silverado and the brake pedal on that is awesome. As soon as you press it, it is firm and solid. I would like my truck to be like this also. I do not think that it would fail in an emergency but I would rather have it right than chance it. If anyone has any ideas I would really appreciate it. Thanks. Josh-(d0dgesst@aol.com)
Old Feb 22, 2009 | 08:33 PM
timber74wolf's Avatar
The ABS valve might be bad. I know my 1990 model had a bad valve for the ABS and they were notorious for going bad. Does your 92 have hte same valve under the master cylinder as your uncles?
dave1125
Feb 24, 2020 04:21 PM
bigwedgies
Jun 25, 2011 03:24 PM
Tiny1987
Jun 8, 2007 04:43 AM
sewerGuy
Jan 14, 2007 10:13 PM
deepz71
Jul 29, 2006 09:26 PM
