95 gmc brake lines
I HAVE A 95 GMC 1500 PICKUP, WELL THE ABS SYSTEM IS BAD THE ECM UNIT FOR THE ABS IS BAD THE BRAKE LINES ARE ALL RUSTED OUT AND NEEDS REPLACED. i WAS THINKING OF JUST GETTING RID OF THE ABS SYSTEM AND GOING BACK TO REG POWER BRAKES, SO HAS ANYONE USED BRAKE LINES FROM SAY A 88 PICKUP, I CAN GET ALL THE LINES FROM THE MASTER CYLINDER TO THE REAR AXLE FROM LMC TRUCK PARTS, I BELIEVE THE WHEEL BASE IS THE SAME. i AM JUST WONDERING IF THE FITTING FROM THE LINES WILL WORK IN MY MASTER CYLINDER AND WHEEL CYLINDERS. tHANKS FOR ANY INFO GUYS
