'98 Silverado RPO decode - transmission?
Old Jan 30, 2009 | 05:03 PM
dmccartyfan's Avatar
Default '98 Silverado RPO decode - transmission?
Hey all - so being the GM Master that he is, and if I asked nicely I was hoping Argon would decode the option list for my '98 - or maybe just list the available options for me and I'll do the decoding. Also, I know AU0 is keyless entry, and it's not listed. Am I limited to aftermarket keyless entry if this option is not listed?
Many thanks, as always!
Here's my VIN:
2GCEC19M5W1252XXX
Here are my options (taken from glove box):
CC10753 (listed along top of decal, not sure if it's relevant?)
... etc, edited, check below for decodes.....
These #s were also on the lower part of the decal:
BC/CC
U 855
13D
Old Jan 30, 2009 | 05:48 PM
Chevyalltheway's Avatar
Default RE: '98 Silverado VIN decode - Argon???
I have the decoding book for 92 but not for that year. Hopefully someone else can help
Old Jan 30, 2009 | 06:12 PM
Ya know what - I think I just found 'em, if they're standard codes. This PDF is entitled 'GM-Firebird-Camaro-GM-RPO-car-codes'. I'll decode and post. Here's a link to the PDF...
http://www.marshu.com/images-website...-car-codes.pdf
I apologize in advance if I'm violating any rules here.
Old Jan 30, 2009 | 06:26 PM
Well, it seems like some of the codes match my truck and some don't - for instance, I have L30, which on this chart is listed as a 327 V8 which I KNOW ain't right...
Old Jan 30, 2009 | 06:57 PM
OK, here's what I got. The top few were not listed, or didn't look right (327 engine, 100A generator, etc.). Also, not sure what is included in things like 'Convenience Package', 'Special Equipment', etc. but everything else seems accurate.
What are these:
K60
L30
R6Q
XFL
YA7
YFL
ZFL
1SZ
6WW
7WW
These look correct:
AG9 ADJUSTER, SEAT, POWER, 6 WAY
AJ1 WINDOW TINTED, DEEP, ALL EXCEPT W/S AND DRS
AM7 SEAT, RR, FLDG
AU3 LOCK CONTROL, SIDE DR, ELEC
A20 WINDOW, RR QUARTER VENT SWING OUT
A31 WINDOW, POWER OPERATED, ALL DOORS
A95 SEAT, FRT BUCKET, HIGH BACK, PASS & DRIVER RECL
B32 COVERING, FRT FLOOR MATS AUX
B33 COVERING, REAR FLOOR MATS AUX
B85 ORNAMENTATION, EXTR MLDG BELT REVEAL
B96 MOLDING WHL OPENING
C60 HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
DK6 CONSOLE ROOF, INTERIOR
D48 MIRROR O/S, REM CONT, ELEC PAINTED
D55 CONSOLE, FRT COMPT, FLOOR
EVA TEST DVT, EVAP EMISSION REQUIREMENT
E24 WWR SIDE, CARGO, HINGED
E63 BODY EQUIPMENT, FLEETSIDE, PUBX
F51 SHOCK ABSORBERS, FRT & RR, HD
GU6 AXLE REAR, 3.42 RATIO
G80 AXLE POSITRACTION, LIMITED SLIP
JB5 BRAKE, POWER, DISC/DRUM, 6400 LBS
KC4 COOLING SYSTEM, HEAVY DUTY ENGINE OIL
K34 CRUISE CONTROL, AUTOMATIC, ELECTRONIC
NB6 EMISSION SYSTEM, CALIFORNIA, TIER 1
NP5 STEERING WHEEL, LEATHER WRAPPED
NRQ EXHAUST, CLOSE COUPLED
N33 STEERING COLUMN, TILT TYPE
N90 WHEEL, 15 X 7,ALUMINUM CAST, 4.75 INCH BOLT CIRCLE
OSG PLANT CODE OSHAWA, ONT, CANADA (TRK)
Q4B GVW RATING 6200 LBS
SLM STOCK ORDER, PROCESSING CODE
UP0 RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV, MUSIC, SEARCH, CASS, CD, AUTO TONE, CLOCK AND ETR (RADIO WILL NOT SNAP FIT INTO I/P – NO ATTACHING FASTENERS, CD WILL BE REMOTE MOUNTED OTHER THAN THE IP)
UQ3 SPEAKER SYSTEM, PERFORMANCE ENHANCED AUDIO
VB3 BUMPER, RR, STEP, CHROME, IMPACT STRIP
VG3 BUMPER FRT, IMPACT STRIP
VG8 VEHICLE, BUYER NOTICE LABEL
VK3 LICENSE PLATE, FRT MOUNTING PKG
VP6 NOISE CONTROL
VR4 TRAILER HITCH, WEIGHT DISTRIBUTING PLATFORM
VXS VEHICLE COMPLETE
V22 GRILL RADIATOR, CHROME
V73 ANTENNA, FIXED
X88 CONVERSION NAME PLATE CHEVROLET
YD3 FRONT AXLE, BASE EQUIPMENT FOR SCHEDULING, GVW PLATE
YD6 REAR SPRING, BASE EQUIPMENT
YE9 CONVENIENCE PACKAGE, COMFORT & DECOR LEVEL #3
YF5 CERTIFICATION, EMISSION, CALIFORNIA
ZQ3 SALES PACKAGE, DRIVER CONVENIENCE II
ZY1 COLOR COMBINATION, SOLID
Z82 TRAILER PROVISIONS, SPECIAL EQUIPMENT, H.O.
1SB OPTION PACKAGE 02
13D TRIM COMBINATION, CLOTH, LT SLATEGRAY (D)
13I INTERIOR TRIM, LT SMOKE GRAY
41U PRIMARY COLOR, EXTERIOR, BLACK
Old Jan 31, 2009 | 12:32 PM
ecutts's Avatar
Does this site provide any more info for you?
http://www.c2e.info/rpocodes/
Old Jan 31, 2009 | 09:12 PM
Ah, great site eric - I'll check it out when I have a minute. Thanks man!
Old Feb 1, 2009 | 12:59 AM
I checked out the site above and it seems to be the same information I found on the other site - some are missing, some aren't accurate for my truck - i.e. L30 on the list is a 327 when I have the 305, etc. However, it's still mostly correct and is a great source for most options! Good to know I have an oil cooler, HD shocks, factory trailer hitch, etc.
I'm tellin you all, this thing is BONE STOCK Nothing's been changed, except I see where it used to have an aftermarket remote start - and since I don't see the RPO 'AU0', I don't have factory keyless entry While I hate to have keyless entry installed by aftermarket - they never seem to work correctly - I'd REALLY dig having keyless entry, especially since I only have 1 chipped key.
Old Feb 1, 2009 | 06:45 AM
acnas's Avatar
K60:Generator: 100 Ampere L30:Engine: 5.0 Liter V8, CPI
XFL:Tire: Front, P235/75/R15 ST TL ALS B/W YA7:Assembly Line Emission Test, California YFL:Tire: Rear, P235/75R15 BW R/PE ST TL ALS ZFL:Tire: Spare P235/75R15 BW R/PE ST TL ALS 105S
Dont know theses:
R6Q 1SZ 6WW 7WW
Old Feb 1, 2009 | 11:23 AM
It's ALLLLLL COMING TOGETHER! Thanks acnas! Interesting - tho I am ignorant - that the front and rear tires have different specs...
