'98 Silverado RPO decode - transmission?
Hey all - so being the GM Master that he is, and if I asked nicely I was hoping Argon would decode the option list for my '98 - or maybe just list the available options for me and I'll do the decoding. Also, I know AU0 is keyless entry, and it's not listed. Am I limited to aftermarket keyless entry if this option is not listed?
Many thanks, as always! Here's my VIN: 2GCEC19M5W1252XXX Here are my options (taken from glove box): CC10753 (listed along top of decal, not sure if it's relevant?) ... etc, edited, check below for decodes..... These #s were also on the lower part of the decal: BC/CC U 855 13D |
RE: '98 Silverado VIN decode - Argon???
I have the decoding book for 92 but not for that year. Hopefully someone else can help
Ya know what - I think I just found 'em, if they're standard codes. This PDF is entitled 'GM-Firebird-Camaro-GM-RPO-car-codes'. I'll decode and post. Here's a link to the PDF...
http://www.marshu.com/images-website...-car-codes.pdf I apologize in advance if I'm violating any rules here. |
Well, it seems like some of the codes match my truck and some don't - for instance, I have L30, which on this chart is listed as a 327 V8 which I KNOW ain't right...
OK, here's what I got. The top few were not listed, or didn't look right (327 engine, 100A generator, etc.). Also, not sure what is included in things like 'Convenience Package', 'Special Equipment', etc. but everything else seems accurate.
What are these: K60 L30 R6Q XFL YA7 YFL ZFL 1SZ 6WW 7WW These look correct: AG9 ADJUSTER, SEAT, POWER, 6 WAY AJ1 WINDOW TINTED, DEEP, ALL EXCEPT W/S AND DRS AM7 SEAT, RR, FLDG AU3 LOCK CONTROL, SIDE DR, ELEC A20 WINDOW, RR QUARTER VENT SWING OUT A31 WINDOW, POWER OPERATED, ALL DOORS A95 SEAT, FRT BUCKET, HIGH BACK, PASS & DRIVER RECL B32 COVERING, FRT FLOOR MATS AUX B33 COVERING, REAR FLOOR MATS AUX B85 ORNAMENTATION, EXTR MLDG BELT REVEAL B96 MOLDING WHL OPENING C60 HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS DK6 CONSOLE ROOF, INTERIOR D48 MIRROR O/S, REM CONT, ELEC PAINTED D55 CONSOLE, FRT COMPT, FLOOR EVA TEST DVT, EVAP EMISSION REQUIREMENT E24 WWR SIDE, CARGO, HINGED E63 BODY EQUIPMENT, FLEETSIDE, PUBX F51 SHOCK ABSORBERS, FRT & RR, HD GU6 AXLE REAR, 3.42 RATIO G80 AXLE POSITRACTION, LIMITED SLIP JB5 BRAKE, POWER, DISC/DRUM, 6400 LBS KC4 COOLING SYSTEM, HEAVY DUTY ENGINE OIL K34 CRUISE CONTROL, AUTOMATIC, ELECTRONIC NB6 EMISSION SYSTEM, CALIFORNIA, TIER 1 NP5 STEERING WHEEL, LEATHER WRAPPED NRQ EXHAUST, CLOSE COUPLED N33 STEERING COLUMN, TILT TYPE N90 WHEEL, 15 X 7,ALUMINUM CAST, 4.75 INCH BOLT CIRCLE OSG PLANT CODE OSHAWA, ONT, CANADA (TRK) Q4B GVW RATING 6200 LBS SLM STOCK ORDER, PROCESSING CODE UP0 RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV, MUSIC, SEARCH, CASS, CD, AUTO TONE, CLOCK AND ETR (RADIO WILL NOT SNAP FIT INTO I/P – NO ATTACHING FASTENERS, CD WILL BE REMOTE MOUNTED OTHER THAN THE IP) UQ3 SPEAKER SYSTEM, PERFORMANCE ENHANCED AUDIO VB3 BUMPER, RR, STEP, CHROME, IMPACT STRIP VG3 BUMPER FRT, IMPACT STRIP VG8 VEHICLE, BUYER NOTICE LABEL VK3 LICENSE PLATE, FRT MOUNTING PKG VP6 NOISE CONTROL VR4 TRAILER HITCH, WEIGHT DISTRIBUTING PLATFORM VXS VEHICLE COMPLETE V22 GRILL RADIATOR, CHROME V73 ANTENNA, FIXED X88 CONVERSION NAME PLATE CHEVROLET YD3 FRONT AXLE, BASE EQUIPMENT FOR SCHEDULING, GVW PLATE YD6 REAR SPRING, BASE EQUIPMENT YE9 CONVENIENCE PACKAGE, COMFORT & DECOR LEVEL #3 YF5 CERTIFICATION, EMISSION, CALIFORNIA ZQ3 SALES PACKAGE, DRIVER CONVENIENCE II ZY1 COLOR COMBINATION, SOLID Z82 TRAILER PROVISIONS, SPECIAL EQUIPMENT, H.O. 1SB OPTION PACKAGE 02 13D TRIM COMBINATION, CLOTH, LT SLATEGRAY (D) 13I INTERIOR TRIM, LT SMOKE GRAY 41U PRIMARY COLOR, EXTERIOR, BLACK |
Ah, great site eric - I'll check it out when I have a minute. Thanks man!
I checked out the site above and it seems to be the same information I found on the other site - some are missing, some aren't accurate for my truck - i.e. L30 on the list is a 327 when I have the 305, etc. However, it's still mostly correct and is a great source for most options! Good to know I have an oil cooler, HD shocks, factory trailer hitch, etc.
I'm tellin you all, this thing is BONE STOCK :) Nothing's been changed, except I see where it used to have an aftermarket remote start - and since I don't see the RPO 'AU0', I don't have factory keyless entry :( While I hate to have keyless entry installed by aftermarket - they never seem to work correctly - I'd REALLY dig having keyless entry, especially since I only have 1 chipped key. |
K60:Generator: 100 Ampere L30:Engine: 5.0 Liter V8, CPI
XFL:Tire: Front, P235/75/R15 ST TL ALS B/W YA7:Assembly Line Emission Test, California YFL:Tire: Rear, P235/75R15 BW R/PE ST TL ALS ZFL:Tire: Spare P235/75R15 BW R/PE ST TL ALS 105S Dont know theses: R6Q 1SZ 6WW 7WW |
It's ALLLLLL COMING TOGETHER! Thanks acnas! Interesting - tho I am ignorant - that the front and rear tires have different specs...
| All times are GMT -5. The time now is 07:12 AM. |
