99 chevy silverado 1500
Old Aug 15, 2011 | 03:58 PM
firelt170's Avatar
Default 99 chevy silverado 1500
I have a 99 chevrolet silverado and when i first got it keyless entry worked. it all of the sudden stopped working i changed battery in remotes and when i went toprogram new remote i cant get it into program mode I am doing the steps corrrectly but after ignition cycle and releease unlock button the doors dont do the lock unlock any suggestions
Old Aug 15, 2011 | 04:08 PM
Wiked's Avatar
check some fuses and relays
Old Aug 16, 2011 | 06:04 AM
firelt170's Avatar
What is the best way to check relay I did check fuse all are good
Old Aug 16, 2011 | 06:15 PM
Wiked's Avatar
i actually dont know haha
hopefully mrdragon will make an appearance. He knows his stuff
Old Aug 16, 2011 | 11:33 PM
NullHead's Avatar
For testing a relay, you should be able to use an ohm meter to get an ohm reading on two of the four/five pins. It's hard for me to describe ... The easiest way is to swap the relay with a known good one from a harmless circuit, such as the horn (only do this for testing while in your driveway/not going to drive it) and see if you can get your circuit in question to work again. I don't know anything about the circuit you're talking about, but check your labels on the fuze box cover, or in the users manual and figure out if you have a relay for the FOB/alarm.
Old Aug 17, 2011 | 08:11 AM
MrDragon's Avatar
I'm a bit stumped on that one too. I remember having some that would take a few tries to program though. You might even go up or down a model year on programming instructions just to see if it might work.
hunter123420
May 20, 2009 01:13 PM
Chevyalltheway
24
Sep 18, 2008 01:41 AM
jken72
Vehicles for Sale
Nov 16, 2007 05:24 PM
scotwea
Aug 28, 2007 05:20 AM
xsst4
Vehicles for Sale
Aug 18, 2007 09:58 PM
