-   -   99 chevy silverado 1500 z71 gas gauge problem (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/99-chevy-silverado-1500-z71-gas-gauge-problem-14337/)
jwener93 Aug 6, 2010 01:36 AM
hey my gas gauge do not work i was wondering if anyone know what i need to replace to get it fixed please let me know thanks
josh
wernersjjc@yahoo.com
rmck490 Aug 6, 2010 05:54 AM
It could be you fuel level sensor in the tank is bad or a bad connection in the circuit. Have it scanned to see if you get a P0462 or P0463 code.
I had this problem and replaced the sensor and wire harness. Works fine now.
RUFFNECK4LYFE Aug 7, 2010 12:33 AM
Fuel sending unit. Its part of the fuel harness in the gas tank. Cheap part but labor is expensive. If done by yourself its pretty easy to unbolt the bed and move it back about 2 feet instead of dropping the gas tank.
02camarossle Aug 8, 2010 02:00 AM
dropping the tank is not that hard, takes about an hour taking your sweet time with a buddy, hardest part is taking the rubber hose off the neck of the filler cap, and tightning the fuel pump back in the tank... the whole fuel pump assembly is about 250 for a ac delco. if you do it your self, to make it easy on your self run your truck till your damn near empty if not empty, and replace the fuel filter also.
RUFFNECK4LYFE Aug 8, 2010 02:09 AM
If you have a buddy, 6 bolts out, scoot the bed back, 20 mins.... done!
mn craigs Aug 13, 2010 08:04 PM
i thought i'd try the "scoot the bed back 2 feet" ... how about tail light wiring and the fuel filler tube?
mike
rmck490 Aug 14, 2010 07:28 AM
The tail light wiring simply unplugs from the bed (there's two). They are on the underside near the tailgate. Don't forget to reconnect them when you move the bed back.
I believe there's two or three screws connecting the filler neck to the bed at the filler port. Just remove those and bend the hose out of the way. There is also a grounding strap at the filler port as well. Make sure it's disconnected from the bed too.
I preferred moving the truck bed to access the tank. You can do this with a full tank of gas. Dropping the tank requires emptying it somehow.
timber74wolf Aug 14, 2010 09:32 PM
I beleive you have to change out teh whole pump which has the fuel sensor level attached. Or can you just replace the sensor?
rmck490 Aug 14, 2010 10:44 PM
I was able to replace the fuel level sensor on the fuel pump unit it's attached to. I believe I got it from Rock Auto.
jwener93 Aug 15, 2010 05:41 PM
does any body know what the name of the part i will need is?
