Lowered 2002 silverado 1500 lower ball joint
Old 12-23-2014, 12:12 PM
Daniel Stout's Avatar
Default Lowered 2002 silverado 1500 lower ball joint
I have a 2002 1500 with a 4/6 drop. I went to replace the lower ball joint and the shank is not long enough to go through the lowering knuckle and get a nut on. If anyone could help me find the correct ball joint I would appreciate it. The moog k6539 is too short and will not work.
Old 12-24-2014, 10:11 PM
After thoroughly cleaning the upper and lower control arms, can you see any kind of identification?
What I'm getting at... The only way to find the correct ball joint is to identify the lowering kit
Old 12-26-2014, 01:07 AM
NullHead's Avatar
That's what I was thinking .. gonna have to see who made the lowering kit for you to be able to figure out what balljoing you need.
Old 01-26-2015, 08:23 AM
I could not find anything on the control arms but the steering knuckle is belltech. I did notice that the ball joints were flipped over from a stock truck.
Old 04-06-2022, 05:28 PM
Ladydubshack's Avatar
Did you ever find the correct lower ball joint? We are having the same problem right now. PO flipped the lower ball joint and the k6539 will not work. We'd like to keep the truck lowered but just can't seem to find the right part!
HugeF250Lift
10-22-2009 11:38 PM
S70P
10-18-2008 09:03 PM
uscghalle
05-09-2008 05:48 PM
majordad
11-05-2007 06:36 AM
majordad
10-18-2007 10:05 AM
Quick Reply: Lowered 2002 silverado 1500 lower ball joint
