99 gmc
i have 99 gmc sierra 2500 work truck brake lights quit working all else works ,even 3rd brake light i have checked fuses,brake light switch, bulbs, circuit boards,all check ok anyone have ideas on what is wrong thanx.... mike
They should work . . .
Originally Posted by mike1965
(Post 80337)
I have 99 gmc sierra 2500 work truck brake lights quit working all else works, even 3rd brake light I have checked fuses, brake light switch, bulbs, circuit boards, all check ok anyone have ideas on what is wrong thanx.... Mike Then they should work ? Check em' at night ! Red, *<(:{)- |
I would check for voltage entering at the printed circuit board. Those boards are renowned for failing. Use a multi meter
If third brake light is working usually turn signal switch is bad. Sometimes if you play with the hazard button, on and off a few times, lights may start working for a while.
