NullHead |
09-24-2015 05:16 PM |
I have a few concerns here, typically I see purge valves causing lean conditions because the engine vacuum sucks the gas tank into a vacuum, and pulls more air in through the normally open vent valve.
If you have black smoke, make sure it isn't oil. Look in the intake, check your oil, make sure your plugs aren't fowling. Purge valves are cheap and easy, I'd replace it. Lean is more harmful than rich, if you're running rich, I would definitely look into it. A purge valve isn't absolutely mission critical to the operation of the vehicle, but I'd get it taken care of.
