-   -   AC compressor clutch not coming on (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/ac-compressor-clutch-not-coming-14627/)
80skeys Sep 10, 2010 10:26 AM
1991 Silverado k1500.
The blower works fine to bring in outside air, but when I press the AC button the compressor clutch does not engage.
  • The AC fuse located inside the cab near the driver is okay
I jumpered the low pressure cut-off switch on the accumulator: but still the clutch does not engage
What's the next thing to look at?
- 80skeys
RUFFNECK4LYFE Sep 10, 2010 11:13 AM
Check the wire for power going to the A/C to see if it is gettin a signal.
GMCSierraFan Sep 10, 2010 12:43 PM
It sounds like if you have power, just remove it and take it to autozone and have them test it.
80skeys Sep 10, 2010 03:24 PM
I checked it. No juice.
80skeys Sep 10, 2010 11:30 PM
Now that I know there's no power to the compressor, where do I look next?
RUFFNECK4LYFE Sep 10, 2010 11:31 PM
Ok next locate the relay for it. Most systems have a fuse and a relay for the A/C. Only way for a quick check is to replace it wit a new one.
Mr_Shamrock Sep 11, 2010 08:23 AM
Also check to see if there is power to one side of the low pressure switch.
I have replaced quite a few of those control heads too. Usually they will flash when there is an issue.
80skeys Sep 11, 2010 10:15 AM
There is no power to the low pressure switch. The control head is not flashing.
I have no idea where the relay is on this truck. Anybody know?
RUFFNECK4LYFE Sep 11, 2010 01:20 PM
I think its behind your glove compartment.
80skeys Sep 28, 2010 02:07 PM
It looks like there are three identical relays in a row from left to right, behind the glove compartment. None of them are labeled as to their function. Anyone know which one is for the A/C?
