-   -   ac compressor shuts off (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/ac-compressor-shuts-off-16929/)
dynedog Jun 27, 2011 10:48 PM
2006 gmc 1500 5.3 litre, ac compressor does not always kick on when started and at other times works great, cannot not seem to get any help from local dealer any would be appreciated thanks.
cubpak89 Jun 27, 2011 11:07 PM
check the ac clutch pully it may be bad
also check the blower motor resistor it could be sending the wrong voltage
also check fuses
more info would be greatly apriciated for better help
dynedog Jun 28, 2011 09:31 AM
ac compressor
thanks for reply, fuses are good checked power to compressor do not know voltage but is getting there, could low pressure be the problem? when compressor runs seems to make cold air, my work for couple days or might not work for same, seems like if not working shut truck off for awhilr and restart may begin working.
Wiked Jun 28, 2011 05:23 PM
it could be low pressure not enough freon in the tubes but if its a 2006 and theres nothing in the system you want to check for leaks
also your clutch may not be engaging or the compressor is shot or leaking
