AC condensation leaking inside
Old Jul 14, 2010 | 11:13 PM
cmikespower's Avatar
Default AC condensation leaking inside
2004 5.3 I was driving with my AC on today (outside temp was 95) and noticed the driver side floor mat had alot of water on it. I could actually see the water trickeling out from under the center console. Has anyone had this problem and how did you fix it? Thanks in advance
Old Jul 14, 2010 | 11:58 PM
1994chevydriver's Avatar
i have never had that problem with my 1994 chevy k1500 z71 but i have heard if you have condensation coming into cab check drain tube that comes out of the firewall under the hood below where your ac lines go into cab to see if it is plugged. on my truck the drain hose is on pass side
Old Jul 15, 2010 | 12:07 AM
mikesheldon's Avatar
Banned
The same thing happened to me! In my case I opened the co-drivers air flowter because my girlfriend was cold and had closed it and no more leaking!! It happens because the cool air presses the allready cool air that can't get out of the flowter and liquids it! simple as that..
Old Jul 15, 2010 | 08:33 PM
chevy112488's Avatar
could be a stopped up drain tube, or a cracked case (the black plastic cover under the dash)
Old Jul 16, 2010 | 10:53 PM
Default thanks for the info.
thanks for the info. how do you remove the center console without destroying it? I guess I'll start with the screws under the console hatch. any info would be helpfull. thanks in advance MIKE
Old Jul 17, 2010 | 01:24 PM
wish i could tell you man but i wrecked the only one i tried to pull out.
Old Jul 18, 2010 | 02:56 PM
timber74wolf's Avatar
Take your time and it will come out. be sure to remove all your screws... I bet it is a stopped up tube.
Old Jul 21, 2010 | 03:10 PM
ok I just removed about 30 screws starting with the console compartment and going forward. I was able to get pretty far untill I tried to remove the side decorative plastics (they run the length of the console) and noticed 2 screws at the top of the console (above the cig lighter) that must be removed which I cant get to unless i remove parts of the dash. I could use some advise on removal in parts or maybe I can pull the seats and try to take the console out whole. Thanks in advance Mike
Old Jul 28, 2010 | 11:10 PM
just looked at removing the seats and there are some sort of star head or temper proof bolts. do I have to remove the seats? and if so where can I get the socket? thanks
garrettnorris
Jun 23, 2013 08:10 PM
agentjk
Jun 7, 2009 02:18 AM
05greygmc
Jul 22, 2007 09:43 PM
djowns
Jul 2, 2007 09:38 AM
abtanner
May 26, 2006 03:37 PM
