-   -   Adjusting emergency brake shoes on 02 sierra (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/adjusting-emergency-brake-shoes-02-sierra-14919/)
Wile e.1. Oct 23, 2010 01:41 PM
Installed new rotors and pads on rear of 02 sierra, now need to adjust emergency brake shoes. Can this be done somehow with the wheel on. I saw the adjuster wheel when the old rotor was removed.Strange thing was the new rotor fit without backing off the E brake adjuster. Looking at it , with the wheel on, there does not seem to be a way of adjusting without mangling the rubber boot that covers the hole where I think I need to be on the back side of wheel. Short of pulling everything off again and adjust that way, Is there another ?
Wile e.1. Oct 23, 2010 08:32 PM
I thought the E brake was hanging up...the passenger side rear wheel was smokin hot after a test drive. Turns out the calliper seems to be not releasing, and holding the pads tight to the rotor. Is it likely the caliper ? or is there some sort of sensor or other part that regulates the pressure. When tested the calipers piston comes out when the brake peddle is pushed, I have been using a C clamp to push piston back in,removing the cap at the master cylinder
RUFFNECK4LYFE Oct 24, 2010 12:13 AM
Sounds like a sticky caliper. A brake flush might fix this but may need to replace the caliper. You will need the flush anyways.
timber74wolf Oct 24, 2010 12:42 AM
Flushing it normally works... aka excedrcise the caliper. And if you bleed one you might as well bleed them all.
Wile e.1. Oct 24, 2010 04:41 AM
Thanks for the info guys. Looks like it is gonna be the caliper. A short time ago I had all the brakelines replaced due to corrosion, 1 of em' rotted through, and since the others were just as rusted, I had all of them changed (and the fluid) That seems to be the only trouble I have with this vehicle.. it only has 30K miles..(huntin and fishin miles :D )This truck is pretty much only driven on the weekends, So anytime there is a problem, it is usually rust related.
austin72 Nov 3, 2010 03:52 AM
The e break is a drum brake set up separate from the disc brake. The rear disc has a drum built in to the back of it and for the adjust there is adjuster on the back of the drum brake assembly and there is a cable adjuster about halfway back on the drivers side where the cable goes from 1 into left and right. I think 12mm nut. When you need of an adjustment, it will go to the floor with very little effort and you can drive through it easily.
