Engine Code and Spark Plug Gap
Old 05-19-2010, 09:14 AM
06ado's Avatar
Default Engine Code and Spark Plug Gap
I have a 2006 Silverado Crew Cab LT3 with 33K. No problems with it or codes but i pulled 4 spark plugs and gap measured .037-.038". Manual says should be .040". Should I regap? Plugs are OEM AC Delco 12571164 - 41-985.
Also the 8th digit of my VIN is Z which I find to mean a 5.3L Flex Fuel engine. I didn't know my engine was Flex Fuel. Is this correct.
I'm think of replacing plugs as my MPG isn't what I would expect and I am a very lightfooted driver. Is AC Delco the way to go or another brand?
Thanks,
Mike
Old 05-19-2010, 06:13 PM
chevy112488's Avatar
z means flex fuel capable. not that you have to run it. but yes its flex fuel capable. as far as the plugs, i'd regap and replace and look elsewhere for your mileage problem. if you do decide to replace them, some people swear by bosch, some by e3 or whatever, i personally go back with factory plugs on a stock engine.
Old 05-19-2010, 06:51 PM
Those plugs should be good for 100K miles, but if you already have some of them out then I guess it would be a good time to replace. I vote for the factory plugs. All those gimmick plugs are a waist of money IMO. Also don't worry about the flex fuel crap...I had a Suburban that was flex fuel and I ran some of the E85 garbage in it for one tank and it ran rough and the mileage offset the cheaper cost of the gas. I never ran it again.
Old 05-20-2010, 08:39 AM
RUFFNECK4LYFE's Avatar
The NGK's have been the best I have put in my GM motor. Much better than the delco plugs. I got a better throttle response out of them.
Old 05-20-2010, 04:31 PM
timber74wolf's Avatar
Which material is the better material when it comes to plugs? Stock from what I have heard is Iridium. Of iridium, copper, platinum, etc... which is the better material for the plugs?
Old 05-21-2010, 06:49 PM
They are puttin iridiums in now cuz they have low resistance and take less voltage to fire. Arcing is what wears metal out between two contact points. The NGK's I suggested are iridiums. As mentioned before, iridiums are made to last 100k before replacing.
Old 05-24-2010, 06:57 PM
Just getting back to the Forum after being out for a bit. RUFFNECK4LYFE which NGKs are you running?
Old 05-25-2010, 09:25 PM
95plugwire
03-29-2012 08:54 PM
danr2960
Silverado/Sierra FAQs
03-28-2012 07:29 PM
patrick300
06-30-2011 07:45 AM
CrazyTexan
05-09-2010 11:22 PM
Buckeye01
08-16-2006 12:22 AM
Quick Reply: Engine Code and Spark Plug Gap
