Air in Brake System
Old Jan 13, 2011 | 10:43 AM
riderj46's Avatar
Default Air in Brake System
I have a 94 gmc sierra 1/2 ton.The m/c went out and and I put a new one on.The truck has abs on the rear only.But I don't have problems with them just the front.I bench bleed the m/c,bleed the brakes.Starting at the right rear first.No air until I drive it for 2 or 3 miles.And then brakes get soft and there's air again in m/c.I have got 3 new m/c's 2 gallons of brake fluid.Theres no leaks or loss of fluid.Any help would be great.The fluid has millons of air bubbles.almost milk color until it clears up.thanks
Old Jan 16, 2011 | 05:32 AM
jvp's Avatar
jvp
Member
It almost sounds like you are boiling your brake fluid, check calipers to make sure they are functioning properly.
jvp
Old Jan 16, 2011 | 08:42 AM
riderj46's Avatar
I have checked the calipers and they seem to be working fine the fluid isn't hot.
jvp
2KSilverado1500
Nov 20, 2011 07:34 PM
mkeyes
Mar 31, 2011 10:07 PM
ncseahawk
Aug 31, 2009 04:38 PM
ferg
Sep 16, 2007 07:32 PM
MMTI
Jan 5, 2006 09:17 PM
