Air Conditioner/Heater only works on high
Like title says, it only works on high. Everything works fine except it only works when it is on highest. I have a 2000 silverado.
Sounds like a blower resistor gone bad. Here is a link to one on eBay
http://cgi.ebay.com/ebaymotors/2000-...Q5fAccessories |
think so? i had a guy tell me it had to be some type of air conditioner switch, because i have options 1-5 from low- high and it only works on 5. im not saying your wrong i just want to be sure before i go by the part i need.
well never mind, i did some researching and i believe you are absolutely correct. thanks
I'm having the same problem. Do you have the part number for the resistor? The ebay link is dead.
Many thanks!! |
no doubt. on high it bypasses the resistor, so if it only works there you know the problem.
Definately the resistor, I had the same problem twice on the 2001 I used to have. Dont' have the part number, sorry.
Part number from Advance Auto is RU1064. Price is $28.99. Takes about 5 min total. 2 min to change the part, 3 more minutes to finish your beer.
Originally Posted by bfg112
(Post 49802)
resistor
After reading another post on this I found the location of the resistor. It's located below the glove box by the fan motor. You have to remove the plastic panel cover to access it. Bought a new AC-Delco resistor (made in SLOVENIA) part #15-81087. Cost me $36 bucks at KOI parts store. Took about an hour. Remember...I'm kinda old. Blower works fine now. After removal of resistor it was easy to see it was a little cooked. Thanks for all the inof on the forum! Next job is fuel pump:( Since I have a fifth-wheel rig in my bed I think we'll try removing the tank instead of the bed...:(
