Anyone know to to get my rear axle out?
Old Aug 13, 2011 | 09:35 AM
Wiked's Avatar
Default Anyone know to to get my rear axle out?
i looked on Ondemand5 but their instructions confused the hell out of me.
im trying to get my diff out of the old truck because its a 6 month old posi and put it in the new truck that has an open rear.
hopefully someone can give more clear directions. i have it down to the point its just the hub and the 4 bolts behind them are off
Old Aug 13, 2011 | 11:02 AM
ghostpopi's Avatar
Member
maybe this will help... How to Remove Car Axles | eHow.com
Old Aug 13, 2011 | 01:08 PM
Wiked's Avatar
thank you.
helps alot more when you can see what you have to do
Old Aug 13, 2011 | 01:46 PM
Wiked's Avatar
right now its the c clamps giving me a problem
Old Aug 13, 2011 | 03:43 PM
Wiked's Avatar
i got both axles out and now my diff is being stubborn and not coming out....
Old Aug 13, 2011 | 04:46 PM
NullHead's Avatar
I suppose the whole axle is rather plug and play. Why not swap the whole rear end?
Old Aug 13, 2011 | 04:53 PM
Wiked's Avatar
because the housing is from the old truck (its really rusty)
and i now have both axles out ans the pinion bolt it just doesnt want to come out and it should slide right out
Old Aug 13, 2011 | 05:22 PM
ghostpopi's Avatar
Member
mite be dumb question but did u remove the nut holding it in? if so try tapping it light to free it.
Old Aug 13, 2011 | 05:34 PM
Wiked's Avatar
yeah unless theres another nut
i got out the 4 nuts that protect the bearing then the small nut that holds in the rod
Old Aug 13, 2011 | 06:02 PM
Wiked's Avatar
i heard there were pins or rings by the bearings that hold them straight and on
