bad brakes at low speeds
Old May 24, 2009 | 12:45 PM
shawn88's Avatar
Default bad brakes at low speeds
Hi i have a 2000 GMC sierria 1500 and have problems braking at low speeds is it the speed sensor and if it is can tell where it is located on the truck.Thanks
Old May 24, 2009 | 02:02 PM
RUFFNECK4LYFE's Avatar
Need more info on ur problem.
Old May 24, 2009 | 07:58 PM
shawn88's Avatar
Default bad brakes
what info do you need when i hit about 30 kmh and lower its like the abs kicks in and when the speed is lower i have to really push the pedal to stop or pump the pedal as soon as i feel it.It is a 2000 gmc sierra Z71 4x4 automatic transmission with a 5.3l motor.I think there was a recall on it but not sure i didnt get any info on it.
Old May 25, 2009 | 06:46 PM
notz's Avatar
Default bad brakes
I have the same problem with my truck, feels that the abs kicks in prematurely....I also can bottom out the pedal at low hard braking speeds. feels very spoungy...I have yet to try bleeding the brakes...
Old May 25, 2009 | 07:41 PM
Honestly it sounds like the Master Cylinder is goin out. Try driving and then when you brake, pump it fast and see if it builds up pressure and the brakes get tighter. If it does then the plunger in the Master Cylinder is goin bad. It is a wearable item meaning its not a defect. Mine went out about 100k.
BirdDooHead
10
Jul 26, 2012 02:45 PM
allgm
Sep 11, 2010 04:39 PM
Rich
Dec 1, 2009 11:37 PM
heathwh
8
Oct 23, 2007 08:14 AM
silverado_ia
Jun 14, 2007 11:02 PM
