Battery light stays on after stopping the car
I have a 2003 Silverado with 6.6 Duramax engine. I have a battery light that stays on when the car is running and after it has stopped. It is a faint light and not as bright as it is when you put the ignition on before you start the car. The bright light stays on about 10-15 seconds after the car has been started and goes down to the faint ligth after that. This ligt stays on all the time even with the ignition of and the car is locked. Is there anyone that can help me with finding out what causes this????
Thanks Tor Inge |
RE: Battery light stays on after stopping the car
sounds like a faulty cluster...check with your dealer,as they are fixing some for free
Ok one problem is that the car is in Norway and I dont know what they will fix over here but I will contact the main dealer over here and see what they say.
Thanks for the answer. The light bugs me a little and it just showed up a couple of weeks ago. Thanks Tor Inge |
they should still fix it..gm is pretty global nowdays
Ok will see what they can do with it. I hope they do it for free. Thanks a lot for the tip. Tor Inge
| All times are GMT -5. The time now is 08:46 AM. |
