beater truck need help
it is a 75 cheyyene it has an older goodwrench 350 in it the carb is a carter quadrajet with abunch of diconnected vacuum hoses.
I pulled the dipstick and it was dark but not that bad . the atf fluid was pink? |
RE: beater truck need help
What is your question??
The ATF fluid should be red, but pink is about right. The oil is probably not a bad thing unless you found that when you start it up it turns milky. The vaccuum hoses can be fixed really easy with a chiltons manual. Any thing else?? |
yeah im planning on making this truck into an offroader the transfer case is a a full time i think because it has a hiloc and loloc position in adition to lo and hi but i dont know what model it is
Isn't the Quadrajet a rochester carb?
| All times are GMT -5. The time now is 08:45 AM. |
