Blown brake line-1994 1/2 ton 4 wd.
Tonight my brake light cam on and there is fluid running out from underneath the radiator.
The master cylinder is on the drivers side. One of the lines goes to a T, and one line goes back and the other under the radiator to the passenger side front wheel. That is the one leaking. My question is, do I have to pull the shroud, radiator etc, or is it ok to re-route the line without all the extra work? |
RE: Blown brake line-1994 1/2 ton 4 wd.
Hey j_remington is a lot easier if you take off the radiator shroud on it has only 4 small bolts on each side of the shroud good luck..
| All times are GMT -5. The time now is 06:56 AM. |
