brake problem
as a mechanic ive seen this many times, you need to pull the caliper off the carrier to make sure the slide pics are free and working, and if they are then chances are its prolly a caliper but try and press the picton in and see if it goes in or not... it also has the ebrake on the in side of the drum which i have also seen stick... wont really know till u get in there...
Thanks snoeboardman137, i'm off work on sun. and will tear it down then. is the hex head nut on the inside of the caliper an 8 or 10 mm? anyway i'll need to buy a set before then. just seems weird that both calipers go at the same time. i bought the truck new and it has 78000 on it. Thanks very much for the insight.
chances are its prolly just the slide pins tho... if they are seized u can get a new carrier or use a torch on the housing where they slide in being careful not to get your rubbers and heat em and just use vice grips or something to try and break em free and then clean em up with a wire wheel and i put never seize on em before puttin em back in... as for the caliper i guess i dont know what your talkin bout... maybe im just reading it wrong? to press the caliper in i use a really big pair of channel locks i got from snap on but you can use a c clamp also...
If both are doing it I would bet it has something to do with the parking brake. Have you tried to hold your parking brake release handle out and pump the pedal a few times. They might be seizing up on you.
dave1125
Feb 24, 2020 04:21 PM
Fivepointstang
Jul 17, 2006 11:45 PM
