Bulletproof Suspension Lift Kit Nissan Titan 2004-2013 2WD/4WD 12"
Old Jan 8, 2014 | 02:54 PM
nick_bp's Avatar
Default Bulletproof Suspension Lift Kit Nissan Titan 2004-2013 2WD/4WD 12"
Quick Overview:
  • Fits all Nissan Titan 2WD/4WD Regular Cab, Double Cab & Crew Cab short or long bed
  • All parts are covered in high quality gloss black powder coat (color upgrades available)
  • Improved ride and handling from factory
  • Factory wheel base and track maintained
  • Wear resistant urethane bushings
  • No welding required, Kit is designed to be entirely "bolt on"
  • All Bulletproof manufactured parts are covered by a lifetime transferable warranty
Bulletproof Suspension Inc. has engineered 12" Suspension System for your Nissan Titan with the greatest design and superior quality Bulletproof Suspension is recognized for. Our Bulletproof 12" Nissan Titan system stands head and shoulders above the competition. All components are made from A36 steel plate 1/4" thick or thicker and heavy wall D.O.M.(drawn over mandrel) seamless steel tubing. We use continuous seam welding and our spindles are of box construction internally gusseted and rosette welded for superior strength and performance. The Bulletproof Suspension Inc Nissan Titan lift kit is for it's name sake "Bulletproof".
Our Bulletproof Titan kit features a one piece lift cage, Fabricated spindle uprights w/ aircraft grade Chromoly Heim outer steering, heavy duty coil over spacers, Atlas Leaf Springs (quoted separately - no blocks or shackle extensions on our kit), complete instructions with photos and hardware kit labeled for each step of the installation. Two shocks are required for the rear and we offer Standard Shocks or Fox Racing Shocks as options. Bulletproof Suspension Uni-Ball A-Arms are also available as up-grades. Weather it be off-road or on road you can count on Bulletproof Suspension getting you there above the rest.
Address:
1316 Agate Avenue, Suite-E
Mentone, CA 92359
Phone: (909) 389 0444
Fax: (909) 389 0439
E-mail :contact@bulletproofsuspension.net
Or bulletproofsuspensionusa@gmail.com
nick_bp
Feb 21, 2019 02:05 PM
nick_bp
Aug 28, 2013 05:58 PM
nick_bp
Jul 2, 2013 06:14 PM
nick_bp
May 22, 2013 11:29 AM
nick_bp
Vehicles for Sale
Apr 11, 2013 11:58 AM
