a/c floor leak
99 silverado and 99 tahoe leak water on floor passenger sidewhen using a/c any help? truck leaks some when in rain. no rust on either. thanks....
RE: a/c floor leak
first,you have to establish it IS a/c water...if it is..
look under the hood and make sure your "boot" is there..its a rubber,90 degree boot on the drain..it prevents wind rush from blowing the a/c water back in the case. you can slip the boot off,and blow air in the drain to try to unclog it... if its not clogged,and the boot is there,AND its a/c water....about all ya can do is remove the hvac case and reseal it |
| All times are GMT -5. The time now is 10:28 AM. |
