A/C and idle speed???
Replaced my ac compressor a few days ago. All went well.
Problem is the compressor only runs for a minute or less then cycles on and off. Whats up with that?? I did double check the freon level and it is good. The outside temp is a little cool right now too.
Also, problem number two. When the compressor kicks on it really affects the idle speed. Much more than it should. Was wondering if it could be the IAC?
Any thoughts...checks....replacement parts that anyone can think of??
Thanks.......
Thanks.......
Yes, took it to a shop and the evacuated the system, leaked checked it and filled it with freon.
I think it is the idle control valve, just not sure?? Was wondering if anyone else has experienced this??
