Center Map Lights not working, all others are working
My 2004 Sierra 2500HD had LED bulbs when I bought it. The door lights, dome light work but the center roof map lights with the buttons don't work.
Every other light works just not those two. Gauge cluster works too. I didn't notice a fuse that was blown and I wouldn't think those two would be on a separate fuse than the dome light
Any ideas?
Any ideas?
Did you figure it out?
I would check voltage to the light socket. Voltage? Bad bulbs. No voltage? Check voltage to the switch. Voltage? Break in the wire to the bulb socket or faulty socket ground. No voltage at the switch? Double check all fuses.
Are these dome lights controlled by the instrument cluster dimmer? Is the dimmer function properly working?
chevy112488
24
Apr 15, 2020 05:46 PM
BrownRecluse
Apr 11, 2015 01:57 PM
1998WK1500
Jan 24, 2014 10:46 AM
Paperboy326
Feb 15, 2009 12:34 PM
