Check engine light 06 V-6 silverado
Old Feb 24, 2011 | 06:54 AM
GEEIA's Avatar
Default Check engine light 06 V-6 silverado
Check engine light comes on...will eventually go off and stay off for several weeks. I don't remember the code but had something to do with coolant or thermostat. Suggestions?
Old Feb 24, 2011 | 07:28 AM
I would take it and have it scanned again - Autozone does it for free. Let us know what the code is at that point. If it is the coolant temperature sensor you will want to replace it. I was left stranded one time because of one of those.
Old Feb 24, 2011 | 07:29 AM
Oh and welcome to the forum!
Old Feb 24, 2011 | 08:45 AM
GEEIA's Avatar
The code was P0128
Old Feb 24, 2011 | 09:22 AM
It could be and probably is a thermostat issue.
The code sets when the coolant temp fails to reach a calibrated temp in a calibrated amount of time so the thermostat being stuck open is the most common culprit.
Old Feb 24, 2011 | 09:46 AM
honestblades's Avatar
Member
Remove the thermostat from the truck. Place it in boiling water with a thermometer in the pot, and see at what temperature it "opens" at.
Old Feb 24, 2011 | 09:48 AM
Member
If the thermostat is the problem then you are in luck. It could be alot worse. A thermostat is very easy to replace,and it doesn't cost an arm and a leg.
Old Feb 24, 2011 | 10:35 AM
GEEIA's Avatar
Thanks.. will check it out.
darkyellowsky
22
Mar 17, 2022 04:27 PM
B-NA$TY
Jun 10, 2014 05:31 AM
makoltd
Apr 2, 2008 08:50 PM
ldiKaty
Dec 4, 2006 01:09 AM
nightcreeper
Oct 25, 2006 07:45 PM
