-   -   Check engine light 06 V-6 silverado (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/check-engine-light-06-v-6-silverado-15919/)
GEEIA Feb 24, 2011 06:54 AM
Check engine light comes on...will eventually go off and stay off for several weeks. I don't remember the code but had something to do with coolant or thermostat. Suggestions?
Mr_Shamrock Feb 24, 2011 07:28 AM
I would take it and have it scanned again - Autozone does it for free. Let us know what the code is at that point. If it is the coolant temperature sensor you will want to replace it. I was left stranded one time because of one of those.
Mr_Shamrock Feb 24, 2011 07:29 AM
Oh and welcome to the forum!
GEEIA Feb 24, 2011 08:45 AM
The code was P0128
Mr_Shamrock Feb 24, 2011 09:22 AM
It could be and probably is a thermostat issue.
The code sets when the coolant temp fails to reach a calibrated temp in a calibrated amount of time so the thermostat being stuck open is the most common culprit.
honestblades Feb 24, 2011 09:46 AM
Remove the thermostat from the truck. Place it in boiling water with a thermometer in the pot, and see at what temperature it "opens" at.
honestblades Feb 24, 2011 09:48 AM
If the thermostat is the problem then you are in luck. It could be alot worse. A thermostat is very easy to replace,and it doesn't cost an arm and a leg.
GEEIA Feb 24, 2011 10:35 AM
Thanks.. will check it out.
