My daughter says it sounds like a cricket
Old 10-05-2006, 04:41 PM
Jamci's Avatar
Default My daughter says it sounds like a cricket
While driving when I give it gas at cruising speed, you can hear a "cricket" sound under the hood. I thought it was the intake or the filter guage. I have since replace the factory intake with a cold air intake but I still get the same noise. Everything on the intake is tight. Any suggestions...theories?
Old 05-18-2022, 08:29 AM
MakeitFitz's Avatar
Default Same thing here
I have the same symptom on my '14. It sounds like alternator bushings failing or intermittant belt squeeling. Mine has 3 belts all are in good shape, tight, and appear to be in alignment. I took a shot in the dark and repla ed the water pump. While doing so I found the tensioner pulley bearings were sketchy. Thought I found it but...nope still sounds the same. It has been suggested to me by someone who's qualifications I can not confirm that it is the DOD system. (Disables 4 cylinders when not under load) Can anyone shed light on how that system which seems to be operating correctly could be mimicking crickets?
baileys
03-10-2009 09:56 AM
jester4
11-21-2008 01:37 PM
Chevycowboy
04-24-2008 10:43 PM
Derekm162
07-23-2007 11:08 PM
kansascolorado
03-23-2007 10:09 PM
Quick Reply: My daughter says it sounds like a cricket
