| TMW |
Nov 25, 2011 07:53 PM |
Chevy/GMC Gas Line Leak
Yesterday I noticed gas dripping from the front of my 04 GMC Z71 gas tank. There are two gas lines at the top of the front of the tank. They go thru a plastic standoff and they both had rubbed the rubber off the, what appears to be, a wire braided line. The top line is where the gas was leaking from and is probably the supply line with the other being the return line. They both connect to metal lines going to the engine after the standoff. I've got 126,000 miles on the truck with many of those being off road. I suggest if you have a chevy or GMC you might want to check the lines for wear. The first signs something was wrong was it taking longer to start after setting a while. Instead of starting on the first couple of engine turns it would take maybe 6-8 turns. Enough to build up the line pressure for the injectors. My problem started Monday coming back from the Baja 1000 but didn't notice or smell gas leaking until yesterday.
