-   -   cuttin' the kitties (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/cuttin-kitties-9567/)
20''strong Mar 28, 2009 09:35 PM
cuttin' the kitties
Anybody cut off their cats?did you just weld in pipe?and was there any codes or lights that came on?
GMCSierraFan Mar 28, 2009 10:03 PM
CATS were stolen off the 92. Just clamped on a pipe where it was(no welding) and there is no difference other than a slightly better aroma to the exhaust :D. i don't know about a newer truck though, but I would think it would mess with all those sensors they've got on em now
98white5.0 Mar 29, 2009 10:54 PM
My 98 has a straight pipe in place of the CAT. No codes. No problems. Smells better than with them. Maybe it's the Carbon Monoxide :eek:
PS: I know CO is odorless, so nobody go trying to tell on me. And Shh about the no cat thing. No one needs to know.
89ChevySilverado Apr 8, 2009 12:13 AM
Here in PA no cat means no pass on yearly inspections... :mad:
That's why its common for the cats to be punched out here... just so you can say its there for inspection. SHHHHHH...
GMCSierraFan Apr 8, 2009 07:05 AM
It's nice with the 92 cuz they don't inspect vehicles older than 2000 anymore. I have to agree with 98white5.0 though, Uncatalized exhaust just smells amazing
89ChevySilverado Apr 8, 2009 09:33 AM
here in PA they inspect anything 1975 or newer:mad: except diesel powered.... unless the truck weight class is over 11,001 pound or greater, then your givin a waiver.... unless your truck is 2007 or newer the you need to have a "Re Generation System" on your truck.....
Personally i feel emmission inspections are BS and as u can see PA is taking it for all its worth.... You know its bad when your truck will PASS emmission in LA,Cail and FAIL in PA...lol:)
98white5.0 Apr 8, 2009 12:35 PM
It's all about global warming. Did I mention it's been the coldest winter here where I live. Hasn't been this cold for at least thirty years, I hear. Sounds like Al Gore might need to come up with another excuse to give speeches.
rxsteven Apr 8, 2009 03:20 PM
It will throw a code and you lose a little torque on the low end.
Mr_Shamrock Apr 8, 2009 03:56 PM
You need to look under your truck and see if it has a O2 sensor before and after the CAT (Upstream and Downstream). If you do than you will definitely get a service light. The ECM compares the reading between the 2 sensors and if they are reading the same (no CAT) than you get a trouble code.
98white5.0 Apr 8, 2009 06:45 PM
I have my cat removed. No SES light. No codes. I have O2 sensors right after the manifolds, before what used to be the cat, and after what used to be the cat. My performance was not affected in any way. I have a single 3-inch pipe after the y-pipe.
