Cylinder #2 Misfire, P0300&P0302
Hi all! Sorry for the wordy post. Short version is I have a #2 misfire and everything appears to be working properly, but suspect the thing is just worn out and needs rebuilding/replacing.
1997 GMC Sierra C1500 5.0 with 188k Quick history: Bought the truck needing intake manifold gaskets. While I was in there, it also got a MPFI upgrade and distributor as they were both trash. The motor was pretty sludgy under the valve covers and in the valley. Cleaned that up as best I could. The good: - Timing was set correctly with a scanner. - Vacuum gauge shows on the low side of good, and steady throughout RPM ranges. - Fuel pressure good and holding. - I’m assuming the injectors are operating correctly, since they’re under the intake and I can’t test them individually. I did remove the upper intake again to make sure I installed the spider correctly and didn’t see anything out of place. The bad: - I have both P0300 and P0302 codes. DashCommand only shows misfire counts on 2. - Compression on all cylinders is between 140-150 dry. Adding oil to #2 raised compression to 170, which seemed significant. - All plugs show some oil fouling but I don’t run the truck much, and have tried new plugs with no improvement. - Spark seems strong at the #2 plug (it shocked me) but pulling the plug wire while running shows no significant drop in idle, especially compared to other cylinders. - Fuel trims are all over the place and exhaust reeks of unburned fuel Does that about cover it? Worn rings and/or heads? Can a mechanic do any additional scanning or diagnostics? Truck is in average condition for its age and I’m not sure it’s worth a crate motor, if it ultimately needs a new one. Thanks for reading. Your thoughts are appreciated. Tom |
| All times are GMT -5. The time now is 04:08 AM. |
