DECODE YOUR OWN VIN #
2000 to Present GM Full Size Truck
17 Digit VIN Reference Chart Position Code Description 1 Country the car was manufactured in 1 = USA 2 = Canada 3 = Mexico 2 Corporation that built the car G = GM 3 Make of the car C = Chevrolet Truck N = Chevrolet MPV T = GMC Truck K = GMC MPV 4 GVWR E = 6001-7000 F = 7001-8000 G = 8001-9000 5 Drive Configuration C = Conventional 4x2 K = Conventional 4x4 6 Weight Code 1 = ½ Ton 2 = ¾ Ton 3 = 1 Ton 4 = ½ Ton HD 6 = ½ Ton Luxury 7 Body Style 3 = 4 Door Cab 4 = 2 Door Cab 6 = Suburban/XL 8 = Utility 9 = Ext Cab 8 Engine type W = LU3 (4.3L) R = L31 (5.7L) N = LQ9 (6.0L HO) V = LR4 (4.8L) Z = L59 (5.3L FF) T = LM7 (5.3L) U = LQ4 (6.0L) G = L18 (8.1L) 1 = LB7 (6.6L D) 2 = LLY (6.6L D) 9 Randomly generated check digit 0 - 9 10 Model year GM decided to give the car Y = 2000 1 = 2001 2 = 2002 3 = 2003 4 = 2004 5 = 2005 11 Assembly plant or location 1 = Oshawa, Ontario F = Flint, MI G = Silao, Mexico J = Janesville, WI R = Arlington, TX E = Pontiac (East), MI Z = Fort Wayne, IN 12 to 17 Production sequence number 000001 - 999999 |
RE: DECODE YOUR OWN VIN #
According to this my truck is a cannuk!! eh...
added the missing x for the 1999 model year
1999to Present GM Full Size Truck 17 Digit VIN Reference Chart Position Code Description #1 Country the car was manufactured in 1 = USA 2 = Canada 3 = Mexico #2 Corporation that built the car G = GM #3 Make of the car C = Chevrolet Truck N = Chevrolet MPV T = GMC Truck K = GMC MPV #4 GVWR E = 6001-7000 F = 7001-8000 G = 8001-9000 #5 Drive Configuration C = Conventional 4x2 K = Conventional 4x4 #6 Weight Code 1 = ½ Ton 2 = ¾ Ton 3 = 1 Ton 4 = ½ Ton HD 6 = ½ Ton Luxury #7 Body Style 3 = 4 Door Cab 4 = 2 Door Cab 6 = Suburban/XL 8 = Utility 9 = Ext Cab #8 Engine type W = LU3 (4.3L) R = L31 (5.7L) N = LQ9 (6.0L HO) V = LR4 (4.8L) Z = L59 (5.3L FF) T = LM7 (5.3L) U = LQ4 (6.0L) G = L18 (8.1L) 1 = LB7 (6.6L D) 2 = LLY (6.6L D) #9 Randomly generated check digit 0 - 9 #10 Model year GM decided to give the car X = 1999 Y = 2000 1 = 2001 2 = 2002 3 = 2003 4 = 2004 5 = 2005 #11 Assembly plant or location 1 = Oshawa, Ontario F = Flint, MI G = Silao, Mexico J = Janesville, WI R = Arlington, TX E = Pontiac (East), MI Z = Fort Wayne, IN #12 to #17 Production sequence number 000001 - 999999 |
#8 Engine type
I have "Y", but it not in your list... 2GCEK13Y471642209 |
chevy truck frame decoder
i have a 1966 chevy truck 1/2 and i am triyng to decode the frame number to see if it belongs to the truck the number is c3z141412 does anybody can help?
I'll check this out, but I know Big Jim is Mexican.
VIN Decoder
Using this tool, you will be able to find out more about the car you are interested in and its history.
Lookup Chevy VIN Decoder on this page |
If you cannot find the VIN, try putting your Vehicle Registration mark (VRM) in one of the following links.
FREE and paid both How to Check a Mercedes VIN https://www.vindecoderz.com/ FREE |
try here
All you need to enter Vehicle Identification Number a
Check Your Chevy VIN navigate here |
