Do i need longer brake lines?
If my truck has a fabtech 7 in lift and if i add a 1.5 in body lift will i need longer brake lines? i didnt put on the fabtech lift and i dont think it came with longer lines.
Crawl under you truck and check them out.
i installed the lift today and they were fine
Nice, post a pic of the truck sir
Looks good man what size tires you running?
315 75 r16
Just for future reference and for any one who may search this topic later on.
A body lift in NO way affects the brake lines, they are on the frame and not the body. That being said the only place a "possible" problem would be is with the master cylinder, but most have coils in the brake lines so that they flex. so it is only a possible problem. |
you just unclip them from the clips on the frame and let them hang there.
