door locks
i have a 2008 gmc 2500hd and not able to unlock doors on driver control but able to do so on passenger side . I took switch apart it is good , jump wires and still not able to unlock , any clues were relay box or controls are located and even a scematic.
2 Attachment(s)
I had the same problem with mine... turned out, it was the switch.
There is a lot of contacts in one switch.. Are you sure you jumpered the right wires? Attachment 2471 Attachment 2472 |
yes I did , I even put the switch on the passenger side and it the same , just wonder were the control Modual is for this .
found problem corroded wire at switch:)
