-   -   egr valve or egr solenoid problem (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/egr-valve-egr-solenoid-problem-18648/)
95gmcss Apr 17, 2012 12:12 AM
hi need a little help my truck is starting to act up i have 95 gmc sierra 350 tbi. when i start the truck in the mornings revs up to 1000rpm and stays that way even when its warmed up but when i put it in gear it drops down to 8 or 700 rpm s normal i think but when i take off slowly or if im driving in high speeds and let of the gas just a little it feels like it not getting enough gas or like if its missing or hesitates , but if i give it some gas it drives fine so i disconnected the hose going from the egr solenoid to the throttle body and the hesitation,missing or whatever went away except for the idling high and of course the check engine light comes and goes so not sure if its the egr valve or solenoid. any ideas i would really appreciate it, thank you
chevychase Apr 17, 2012 06:32 PM
On the high idling check for vacuum leaks . Throttle body gasket .
Maybe the tps/ throttle position switch located on passenger side of throttle body. Or a bad coolant temp sensor located beside the thermostat housing.
Need to scan for codes.
95gmcss Apr 17, 2012 10:01 PM
thanks ill go ahead and check that out
95gmcss Apr 25, 2012 03:18 PM
idling problem
I got a 95 gmc pickup 5.7 when i start it it idles at 1400 rpms for a few seconds then it drops down to 1000 rpms which i think its still to high but when its in gear it idles at 800 rpms just replaced the egr valve and check for vacuum leaks and its all good need help figuring it out, any ideas would help thank you.
