Electric Mirror Crazy Problem
I have a 2000 Sierra with electric side view mirrors (Not Heated & No Turn Signals). One day the switch didn't work at all. I took it apart and cleaned the contacts under the rubber diaphragm. Then only Up and Left worked (both mirrors). I cleaned it again and had all functions for a day. Now, only Up and Left work. It is the style with a rectangular Left-Right rocker above the square tilting directional switch.
I bought a junkyard's "Used & Tested" switch. It does the exact same thing. I traced the wires, looking for a break. (That wouldn't make sense, because it is left and right mirror, but I looked anyway.) I also did the contact cleaning thing on it. I tested the wires and found good 12 volts on the orange and 2 negatives (all from the window switch blocks). At the left mirror I have: Yellow: Positive 12 volts when the switch is pressed Up & Left Negative 12 volts when the switch is pressed down and left Green: Positive 12 volts only when the switch is pressed down Negative 12 volts only when the switch is pressed up White: (Connects to Blue @ Mirror Tail): Positive 12 volts only when the switch is pressed right Negative 12 volts when the switch is pressed left. All Wires: There are stray voltages all over the place when any switch direction is selected. They range from 1 to 5.3 volts. It seems as though the switch will not only send power to the selected mirror, but reverse the polarity for directional control. I can't get a hold of a wiring diagram and the switch has an evil circuit board inside that I can't access for a peek without destroying the switch. I get the same results with the new switch and my old switch. I can't believe that the "Used & Tested" switch and the old switch have the exact same problem. Conversely, I think it is the switch because no wires are damaged, it is common problem to both mirrors and it worked fine for a day after it failed. I suppose these switches fail a lot because used ones are difficult to find. Before I spend a bunch of money on a new (not returnable) switch or another "Used & Tested" switch; do any of you have experience with this problem? Is it a common symptom? Thanks very much! Paul |
hey bird this is not a big problem some day before same problem happened with my uncle. just consult to your mechanic.
