Engine sounds funny kinda like a dink dink dink
Old Feb 29, 2008 | 06:22 PM
Toolman's Avatar
Default Engine sounds funny kinda like a dink dink dink
almost sounds like metal hitting metal deep inside the motor
any ideas
Old Feb 29, 2008 | 06:50 PM
Toolman's Avatar
Default RE: Engine sounds funny kinda like a dink dink dink
Im thinking maybe a can of SeaFoam might do the trick
Old Feb 29, 2008 | 07:14 PM
TheStreetForce's Avatar
If it is a light and crisp dink dink or tapping up near the valve covers is obviously a valve tap. Fix: Retiming.
If it is a knocking when you hit the gas, Predetionation. Usually caused by crappy gas and worn cylinder/piston walls or and combination of the two. Fix: Pro Mechanic for testing
If it is a knocking that is steady throughout the rev even at idle there is a "condition" entitled piston slap.. When there is enough room the piston is rocking back and forth on the wrist pin. If left unchecked some day it will wear enough, jam on the way up and break/bend connecting rod... wrist pin... crankshaft... etc.
If you have knocking worries see your dealer/mechanic. There is usually no quick fix for knocks but its obviously more common in high mileage engines. Hope these words help rule out...
Old Feb 29, 2008 | 10:46 PM
72charger's Avatar
Um.... this couldn't possibly have anything to do with your previously posted thread about doing 164 with the tack pegged and you spraying nitros could it? Not to sure what you expected there.
Old Feb 29, 2008 | 10:57 PM
rxsteven's Avatar
HAHAHAHA!!!!Thats not funny
Old Mar 1, 2008 | 10:08 AM
Argon's Avatar
sounds like a rod
Old Mar 14, 2008 | 04:26 PM
knoxy's Avatar
fix it fast! its got to be a rod! i had the same thing on my toyota and the mechanic said dont worry about it!!!! bull ****! i was cruizing home one day and when that rod snapped it shook my truck so hard it almost drove off the road! not even jokin! get it resleeved or rebuilt.
argon, is it sleeves or new pistons that you need to fix this??
Old Mar 14, 2008 | 11:32 PM
72charger's Avatar
Just dump a quart of Slick 50 in there and don't worry about it............ Although considering he hasn't reposted here I'm thinking maybe the engine already took a dump.
Old Mar 16, 2008 | 01:41 AM
knoxy's Avatar
lol... that would suck!
Jamci
May 18, 2022 08:29 AM
TJsierra1500
Feb 24, 2010 10:17 PM
screamingijit
Nov 21, 2008 01:51 PM
1996silverado
May 19, 2008 02:22 AM
txtravster
Jan 10, 2008 11:45 AM
