-   -   Exhaust Manifold bolt access (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/exhaust-manifold-bolt-access-3074/)
quietguy Apr 22, 2007 09:42 PM
Hi, I have a 90 GMC dually with the 5.7, and I am in the process of replacing the driver's side exhaust manifold. The forward two bolts are actually studs with an accessory bracket mounted between nuts on the studs. I can not figure out how to remove the bracket to access the last two nuts. The bracket supports the alternator and, I think, the power steering fluid resevoir. The nut that I can not get to is in the lower portion and appears to be attached to the resevoir. Does anyone have a suggestion before I sawz-all it?
Thanks
Argon Apr 22, 2007 10:37 PM
RE: Exhaust Manifold bolt access
This is a 350?
Its tuff to get just that bracket off....I think its intended for you to remove the p/s pump,with the bracket attatched to it.
I'm sure it can be done,though.
quietguy Apr 23, 2007 12:01 AM
Thanks Argon,
I checked the other bolts and it looks like I've got to pull the belt, pull a pulley and maybe be able to get the second mounting bolts. Still not sure, though.
Argon Apr 23, 2007 12:26 AM
Yeah,I'd pull the pulley...then the bolts...The good part is you don't have to REMOVE it,just move it outta the way a bit
perron_ts Apr 25, 2007 03:01 PM
Hi, i also have a 90 sierra with a 5.7 and EVERYTHING needs to be replaced in terms of exhaust. Is it possible to have a nice sounding exhaust without spending tons of money? Also, if that's not realistic, any suggestions on what I should go with?
any and all responses welcome
thanks
Argon Apr 25, 2007 04:17 PM
Ask scchevylover...he's over in the chevy section
94gmc 454 May 1, 2007 07:20 PM
perron_ts:
What i did to my truck is remove all pipebefore the catalytic converter offand take a 4 foot straight pipe into a cherrybomb and off the other side another piece of 4ft straight out the end with a 90 degree pipe, it sounds very good at idle and pretty mean when u hit it. its very cheap, as long as you have a welder and a few clamps your good to go and it only takes about an hour tops. after you have your straight pipe welded together
Argon May 1, 2007 07:46 PM
get the manifold on??
