-   -   Front wheel seal (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/front-wheel-seal-3577/)
nhbp06 Jun 29, 2007 02:03 PM
Front wheel seal
I am replacing the front wheel seal on my buddies 00 1500 2wd silverado and after taking off the 3 bolts in back I cant break the seal where the dust shield is any ideas, or am i missing something? Thanks
Argon Jun 29, 2007 02:16 PM
RE: Front wheel seal
take the axle nut off??
nhbp06 Jun 29, 2007 04:22 PM
theres no axel, rear wheel drive, working on the front
stopspazinout Jun 29, 2007 04:34 PM
you say its 2wd? if its 2wd, you have to pop the dust cap off the center of the rotor to expose a castle (axle nut) and cotter pin. THESE MUST BE REMOVED IN ORDER TO REMOVE THE ROTOR!!!
Argon Jun 30, 2007 05:19 AM
ok,my mistake..I thought we were talking 4wd for some reason./..\
yes,its just stuck...remove the 3 bolts out the back and your wheel speed sensor wire....
you say "seal"...I assume you mean the front hub??
nhbp06 Jul 2, 2007 04:29 PM
yes iv tried everything and still havent gotten it off
Argon Jul 2, 2007 05:51 PM
Are you in a corrosion area?..I've really had to beat the snot out of some rusty ones
