-   -   fuel gauge question (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/fuel-gauge-question-16170/)
ghostpopi Mar 21, 2011 10:30 PM
fuel gauge question
i have just bought 88 silverado, an the gas gauge reads half tank all the time.....
is problem the gauge? or sender unit? :confused:
Mr_Shamrock Mar 22, 2011 07:08 AM
As far as the popular culprit I think the sender acts up more than the gauge, however it is not set in stone and could be the gauge as well. As far as how I would go about checking it - I would unbolt the bed (easier than it sounds) and pull the pump and sender out to see if it is stuck. Unless you have access to a similar truck that you can swap entire clusters to see if that helps. The cluster swap is definitely easier, but from my experience the sender is usually the issue.
