-   -   fuel pressure regulator (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/fuel-pressure-regulator-10262/)
bpa1216 Jun 1, 2009 04:03 PM
How hard is it to change the fuel pressure regulator on a 98 gmc sierra 5.7 L. Any help or directions would be greatly appreciated.
RUFFNECK4LYFE Jun 1, 2009 05:14 PM
Pretty easy. Look on the fuel line for the regulator. There is a clip that holds it in place. Some are pull clips and others are C clips that you have to use needle nose tools to take off. Once you take it out, it should pop out or you may have to wiggle a little. Before you do anything, relase the pressure form the system. There should be a valve stem on the fuel line. Looks like a place to put air for a tire. Stick a phillips screwdriver in there with a rag over it cuz it will shoot out for a second. After that then your home free.
RUFFNECK4LYFE Jun 1, 2009 05:19 PM
http://autorepair.about.com/library/images/bl875lib.htm
bpa1216 Jun 1, 2009 06:08 PM
Thanks for the reply, still not certain of the exact location.
vortechpower Jun 6, 2009 01:42 AM
Mine is on the sending unit in the tank. I replaced the whole sending unit, it comes with it.
