-   -   Funny Chirp noise when i start and stop (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/funny-chirp-noise-when-i-start-stop-1670/)
Mfuerst Sep 23, 2006 03:26 AM
Hello,
I have just reciently bought a 1999 GMC sierra 4x4 Z71 extended cab with 103,000 miles on it. It is a beautiful truck... My only issue so far is that whenever i start or stop kinda quickly i hear a funny chirp type noise coming from what seems to be the front driver's side. It doesnt seem to be a suspension noise cause it doesnt do it when i go over bumps or if i swerve just when stopping and starting off kinda quickly.... any ideas? ( it sounds sort of like brakes grabbing hard squeak/chirp, but its not the brakes cause it does it when i start off from a stop also....... i wish i knew how to better describe the noise)
thanks guys
Mike
Mfuerst Sep 23, 2006 03:13 PM
RE: Funny Chirp noise when i start and stop
ok i think its the yoke that goes into the transfer case......... where do i go about getting the nickel plated replacement yoke?
Mfuerst Sep 24, 2006 04:11 PM
zzzzzzz
curtis85 Sep 27, 2006 12:28 AM
that is only a universal joint on the drive shaft, quick fix
hobiekat Feb 10, 2007 03:29 PM
had the saME PROBLEM. itis the yoke going into the tr. undo and pull it out of the transfer case, put a handfull of grease where you pulled the yoke from.
jasonknight Feb 24, 2007 02:48 AM
how do you permanately fix the problem.....is there a new yoke or something? where is the slippage, in the splines......can this problem lead to otheres?
jasonknight Feb 24, 2007 02:49 AM
x
westex39 Feb 24, 2007 05:30 PM
There is a TSB on this. You need a new nickel plated driveshaft spline. Packing the spline with grease is a temporary fix at best.
Sam_Adams Mar 26, 2007 09:30 PM
If it was in the back it could be the leaf springs rubbing together. Jack it up and put grease in between the leafs. Was told that today by a reliable mechanic.
