Gauge cluster question?
Have a cluster that looks like this one sitting in my garage......
http://good-times.webshots.com/photo...01625768pIltKT was wondering if it would be compatible with the plugs for the factory cluster in the 88-94 series?? if so, then i could just swap clusters?? if not, then that must i do to use the other one or is it not possible to use it? thanks in advance:) |
That looks like a 91 - 94 cluster. It may work - plug it in and see. It's an easy swap. Let us know if it does.
Originally Posted by Mr_Shamrock
(Post 46324)
I was thinking that the only issue i may have is that the tach may not work... if so i would have to trace witch wire makes it work and hook it up.. soon as i get some time ill try hooking her up and see what happends:) |
If it won't work on your truck, I'll take it, I'm sick of my 85mph speedo and not having a tach
| All times are GMT -5. The time now is 05:24 AM. |
