| gpet6669 |
Feb 20, 2009 05:16 PM |
The fuse is in the main fuse panel under the hood on the driver side. I had the same problem with my 98 and I had a bad hub. Now that I think about it I think my other hub is on it's way out, even though it is not doing the false ABS engagments.
Check your front hubs and see if they need to be replaced.
-Chrisbmo2000, warped rotors will not be the same feeling due to the ABS pump coming on when brakes are applied and only doing it at certain points. Warped rotors you would feel all the time and wouldn't be hit and miss. Nor would you hear the ABS pump come on and the feel of the peddle is totally different when the rotors are warped vs the ABS pump pumping the brakes.
I used to live in ND and it gets really icey there, in fact I drove on nothing but ice for a month straight. I know what the ABS pump feels like in a multitude of vehicles. It was so cold there the grave roads were iced over and forget about the mud. That is a FROZEN HELL HOLE! Literally.
