gmc 01 runs and dies
Old Jun 7, 2008 | 10:29 PM
natedog2008's Avatar
Default gmc 01 runs and dies
01 gmc 130,000 miles runs 15-20 sec then dies
fuelrail psi reads 10psiI'm pretty sure that this not enough but I dont know the correct psi
anyone have any ideas or suggestions
thanks in advance
Old Jun 16, 2008 | 10:15 PM
92gmcowner's Avatar
Default RE: gmc 01 runs and dies
ok well it sounds like that you have a very weak pump because that does not sound like the correct psi i am unaware of the correct psi but what you are getting does not sound right make sure that there is not a secondary pump under neath the cab in the fuel line, it would be attached to the frame, if there is one then that means that your in tank pump is properly working and the other pump is not pushing enough to keep the truck running
Old Jun 21, 2008 | 03:05 AM
zimsilverado's Avatar
Pressure should be approx. 50# with vacuum to the regulator, 60# without.
dkrood
Apr 1, 2018 03:43 PM
PappyJim
Jun 3, 2014 09:52 AM
skipMore
Aug 5, 2006 04:13 PM
skipMore
Aug 3, 2006 06:49 PM
general z
Aug 1, 2006 05:58 PM
