Grinding/Binding left side in 4wd
Check to see if your CV joint is bad on your axle shaft, or maybe your wheel bearing. Raise it up and turn your wheel all the way to one side, and spin the wheel by hand to see if you can hear the noise. CV joint usually will make a kind of popping or snapping noise. A bad wheel bearing will some times grind when turning. I have found when a right side wheel bearing is bad, it will grind when turning left, does yours grind turning right?
noticatoxin
Sep 22, 2011 10:16 AM
paparoach
Jun 25, 2009 08:21 PM
