-   -   grinding/rattling noise (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/grinding-rattling-noise-7327/)
jcormier89 May 24, 2008 03:20 PM
hey guys, since i bought the truck a couple years ago my 2000 silverado makes a grinding/rattling noise on the passenger side somewhere around the back of the cab or maybe the front of the bed. It ususally only does it when i take a right turn, or if people are in the back of the cab. I have no idea what it is and it really bothers me. anybody else have the same problem? THANKS!
Chevycowboy May 25, 2008 02:17 PM
RE: grinding/rattling noise
Icant think of anything that would really be affected by turning behind your cab. rattling or grinding couldbe a number of things. Does the noise happen when your sitting still, or just when under way? How random is it? Describe the noise a little better, I've had tons of noises from various components going out on my 01' so i'm pretty good with detecting them.
jcormier89 May 26, 2008 08:58 PM
it does happen sometime when ive been driving and stopped at a light...its never started doing it when in park...and it always happens when there is weight in the back of the cab, and sometimes happens when i make the turn...i cant think of any other way to describe it...thanks for the help
rxsteven May 26, 2008 09:18 PM
Check your heat sheilds
Chevycowboy May 26, 2008 10:34 PM
Maybe U-joints. Sounds like drivetrain. If its happening at low speeds have someone walk next to your truck and try to rule things out.
jcbst12 May 27, 2008 08:16 AM
Check the body mounts in the back near the cab. I heard of these getting crap in them and needing to be takin apart and cleaned. Sometimes they get rusty too around the mount itself and the area needs cleaned and touched up.
jcormier89 May 27, 2008 09:30 PM
thanks guys i really appreciate the help
slayer305 Jun 1, 2008 10:11 PM
Look at the starter. I had a 99 a few years ago that the starter bendex went out and made a awful noise. Clankingrattling type noise. Starter worked ok but with the bendex broken it kept clanking against the fly wheel.
jcormier89 Jun 1, 2008 10:48 PM
i dont think it can be the starter cause the noise comes from the rear passenger side of the cab, or so it seems
tboz89 Jun 8, 2008 08:09 PM
as retarted as this may sound the back of my bed was bent in on my 97 it was touching the cab and it was making a racket at random times and it took a day or 2 to figure it out
