Having a problem...
So yesterday I installed my new Cold Air Intake and eveything went all fine and dandy until this morning I got up to go to work and my ac is not working. All it does is blow hot air and that's it. Any suggestions?
Well as long as you didnt touch the ac or anything i wouldnt understand why it would stop working with a cai? Check ur freeon lvl and compresser to see if it is turining on
Ok man thanks alot. I'll try and see What I can do the only thing that sucks is I'm at work and I won't be able to do anything till later! Haha
There is a mini fuse for the ac clutch inside the drivers door and dash. Maybe it popped.
Sounds like you may have pulled the low pressure switch plug loose at the compressor.
Wait guys... We need more info about his truck. What year and such. It could just be the module behind the A/C controls that went bad like mine did.
